929 cuts out while riding and dash lights go out
Old 01-29-2013, 04:47 AM
blade929's Avatar
Registered Users
Default 929 cuts out while riding and dash lights go out
Hi all.
My engine cuts out while riding, and all lights go out on display at the same time.
If i turn off the key and back on again it all fires up again and runs normal, then a while later it happens again.
Can anyone help me please?
Old 01-29-2013, 09:36 AM
74demon's Avatar
With the bike running, wiggle the harness and connectors. Pay close attention to the ignition switch harness and connector, and also see if it dies with a little pressure on the key in either direction. Make sure your battery cables are clean and tight as well.
It's bound to be a bad connection somewhere. There is a larger plug that connects the front harness to the main harness that have been known to have wire issues. Make sure to look at the wires on the ecu too, another spot that can cause problems.
Old 01-29-2013, 01:12 PM
blade929's Avatar
Registered Users
Hi demon,
I will take a look at the thinks you have said.
Where do i find the ecu?
Old 01-29-2013, 01:30 PM
74demon's Avatar
Under the seat, by the battery.
Old 01-29-2013, 01:44 PM
blade929's Avatar
Registered Users
ok thankyou.
will let you know how i get on.
Old 01-29-2013, 06:08 PM
Conrice's Avatar
ya, it's gotta be an electrical connection. almost sounds like you're losing a ground. the battery one might be tight, make sure the one that goes to the starter (or at least that's where the motor grounds on the 954) is tight too.
Old 01-29-2013, 08:43 PM
CTcbr929's Avatar
July 2012 Ride of the Month
Good tips from the CBR pros!
Im gna check my connections soon even tho I dont have this problem.. can never be too cautious!
Old 01-30-2013, 06:13 AM
sj66's Avatar
Check where the earth goes on to the rear swingarm ( centre in front of the wheel) a stack of 3 clean between them
Old 01-30-2013, 11:52 AM
blade929's Avatar
Registered Users
thank you all for your posts, very helpful !!
will let you all know soon.
Old 02-01-2013, 08:12 AM
blade929's Avatar
Registered Users
Hi all.
I have had a look at my bike at the things you have recommended ,and it seems that it is the key, if i start it up and then wiggle the key a little bit it cuts out and loose display, how can i resolve this matter?????
Quick Reply: 929 cuts out while riding and dash lights go out
