Won't stay running with choke off...
Old 05-19-2009, 11:28 AM
DarkWing's Avatar
Default Won't stay running with choke off...
I have a '99 model 900RR it recently was repainted and had all the plastics off and gas tank. It was down for about a month and on yesterday once put back together the bike starts fine and I let it run until it was warm. But, as soon as you drop the choke it dies. Also if the throttle is turned a hair while the choke is drop it will run just fine then as well. what could the problem be?
Old 05-21-2009, 06:01 AM
k4y_d1's Avatar
Maybe carbs problems.. i'd try cleaning them thoroughly and sync them.
Old 05-21-2009, 09:59 AM
Bean600's Avatar
carb clean
Old 05-21-2009, 12:22 PM
1badeg's Avatar
Yeah its been sittin for a month...probably have gunk in tha carbs...clean them up and sync em you should be good to go after that.
Old 05-23-2009, 09:43 AM
SGTSKiP's Avatar
I had the same problem after I bought mine. Your secondaries are clogged more than likley. Mine had sat for 4 yrs. But sitting for 1 month should not cause that problem
Old 05-24-2009, 05:04 PM
Bon's Avatar
Bon
Bon is offline
had a similar problem with an older bike. after much time wasted it turned out to be a faulty fuel tap restricting fuel flow. just an idea. good luck
Rubicon on 38s
10-13-2019 11:14 PM
ryant26
F2 Tech
05-14-2011 06:42 AM
ebinz88cane
02-24-2010 11:51 AM
transman50
07-06-2007 02:54 PM
mattbt
01-23-2006 08:52 PM
Quick Reply: Won't stay running with choke off...
