wheres the flasher located?
in regards to this - http://www.clearalternatives.com/flasher.htm - ,wheres the flasher located on a 93 cbr900rr?
RE: wheres the flasher located?
I did it two days ago... no problems what so ever...
The flasher for my bike is different than the one you see on the site. It's part of the gauge cluster and not something you can change. I will test this in a few days... but I believe if we add the flasher to our signal wiring anywhere, it will cause a load to put back on the flash pattern that we remove when we use LED and slow it down again. This is my theory. I have the hotbodies racing LEDs on order and I'm afraid when I install them... my flash will be to fast to see. For now with just the CA integrated tail light... it's fast but usable.
Here's the location for the 96-98... might be the same or close for yours.
