valve clearance help....
Old 04-09-2008, 06:10 PM
bindelsf2's Avatar
Default valve clearance help....
if anyone has a clymers could you please tell me what the valve clearance is for the 893cc... i have a clymers but its for the f2 and i have the 900 engine in it and i dont want to buy a manual just for valve clearance...
and yes i did multiple searches and nada..
Old 04-10-2008, 04:41 AM
Default RE: valve clearance help....
Hey there bindelsf2
I have a Heynes manual for the 96 to 99 CBR900. I sent a screenhsot of the manual with the valve clearance section. There is a block circled in red for you to use as a reference if you get any more replies. I would assume that this is the valve clearance for pre-96 Fireblades.
Hope it helps.
Old 04-10-2008, 04:13 PM
bindelsf2's Avatar
good stuff!! thanks a ton. thats what i thought it was but wanted to be sure!!
thanks again!
Old 04-14-2008, 04:21 PM
bindelsf2's Avatar
can anyone else verify that the 893cc and the 919cc are the same.... thanks a TON!!
Old 04-14-2008, 09:25 PM
SpiritRR's Avatar
Intake valve clearances are the same for all models. Exhaust valves are the same for 93-97.
Intake: 0.13--0.19 mm
Exhaust:
93-97 0.19--0.25 mm
98-99 0.22--0.28 mm
Obviously, if you're running the 893, the 93-97 bracket is where it's at. Good luck bindel!
Old 04-15-2008, 04:10 PM
bindelsf2's Avatar
good deal. i got them all done last night and thats what i used... thanks again guys!
greggmet
04-08-2012 04:58 PM
ILLTech
05-03-2009 03:40 AM
eljrc16
11-26-2008 03:04 PM
ken12
01-24-2008 06:39 PM
rrasco
08-28-2007 12:43 PM
Quick Reply: valve clearance help....
