Valve clearance /cct retract?
Hi guys. I'm trying to check my valve clearances. I got the cover off. My manual says to retract the cct without removing it (cause there is no need). I don't have the honda locking tool. It shows a way to make it out of steel but that seems like a big hassle. Should I just take the whole thing off? Will that be easier? Its automatic so I dont have to adjust it to put it back on , right? I was told u dont need to retract the cct to check clearances but the manual says to do it. Thanks
Yes, It's done. I checked the clearances and they were perfect. No adjustment needed. Intakes were all .007 and All the exhaust were .010 except one was .011. Anyway, I retracted it like the manual said to. I have read conflicting answers as to whether you should retract it or not. I stuck a small screwdriver in there and wound it up and clamped it to the bike with a woodworkers clamp. It came off a few times but I put it back on. Even the honda manual says to do it so..... I should've made a video for youtube. It was actually pretty easy (Even if I messsed something up hehehe
and I actually thought his video wasn't bad, I was going to go dig it up but seeing your allset I wont bother..
jay
