Upper trip tree help.
Old May 19, 2007 | 02:04 AM
psycojester's Avatar
Default Upper trip tree help.
So when i crashed my bike i damages the left clip-on, I took off the upper triple tree and now i'm starting to put it back togeather and someone said the the center nut had to be torqued. Is this true? what is the torque spec? Thanks
Old May 19, 2007 | 03:52 AM
zerochickenstrips's Avatar
Default RE: Upper trip tree help.
True to a degree. If you don't tighten it enough, it may back off. I'm guessing it prob. torques to somewhere in the 70 to 80 lb/ft range. The important nuts are the two underneath the upper tree...these two control the pressure on the roller bearings inside the neck (the upper one is a locknut). If you overtigten, the bearings will be clamped too much and thefront wheelmay have a tough time finding its center, causing you to look like a fool weaving from side to side.
Old May 19, 2007 | 04:00 AM
Yea thats what i thought two. So instead of acting a fool down the street i figured i would ask if anyone knew. Thanks
mzk4lyfe101
Jul 26, 2010 11:27 PM
Heylerds
F4i - Wanted
May 30, 2010 07:44 PM
shawnyc01f4i
Feb 28, 2008 10:32 PM
