Sythetic OIL
RE: Sythetic OIL
My two cents is that a moto should only get full-synthetic oils. I have recently been doing a lot of reading about oils because my car is a VW passat with the 1.8 turbo. There is a lot of controversy regarding those engines becuase of sludge issues, and audi and VW have both made synth oils mandatory to enforce the sludge warrenty on thier engines. Another site that i thought was really informative was bobtheoilguy.com.
Bottom line is: Use synths becuase of better ability to withstand shear force (super important in bikes becuase of the wet clutch), and also better because maintians viscocity better under high temps (motos run way hotter than cars, especially around the friction points). Also is helpful to know that what are called 'full synthetics' and 'semi-synthetics' are different in different countrys. Group IV oils are considered full-synthetic in the US, but semi-synthetic in Europe and a lot of other countries because they are actually highly refined-mineral oils. These are the lowest grade oils I use in anything. I have also been sending in oil samples for analysis for my car and my bikes every-other oil change for about the last 4 years, and the Group IV (full synth in the US) oils do hold up noticibly better than the Group III that I was using before.
I have also been reading that it doesn't matter what full-synth you use, as long as it is not marked as EC (Endegy Conserving) oils, becuase they create less binding force in the clutch and cause it to slip. I have used them several times and haven't noticed it as an issue, but I am not a really hard rider so may just have to push the clutch a little harder to have it as an issue. Whew . . . long post, now i'm done.
