Speedo only displays intermittently
97cbr RR 918
Sorry for all these probably daft noob questions but here goes another one the speedo only displays very intermittently ☹️ previous owner gave me a new (second hand/looked the same as the not working one)cable which I have fitted but still the same problem is there anything else I should check would a New cable solve the issue https://cimg8.ibsrv.net/gimg/cbrforu...8e6bfc7df.jpeg does anywhere produce new cables again much thanks to the acquired knowledge of the biker hive mind ✌️ |
this is pretty easy - find the part numbers..
https://www.partzilla.com/catalog/ho...ter-tachometer search on eBay.. https://www.ebay.com/itm/13410125039...3ABFBM4uv-kIRi |
Cheers rockpool👌👌👌✌️
as to whether it will sove the problem - who knows? Difficut to test those cables. Make sure anything which moves is moving properly I guess?
