Reoccuring Charging Problem???? SOLVED!!
Your problem is its not charging. The stator only makes voltage w/engine running. 12.8 volts is just battery no load volts. You need to have around 15 volts measured at the battery engine running at about 5k rpm's. The first thing is get rid of the aftermarket reg. Go w/the Honda part, ask any dealer svc. mgr. its pretty common.
ORIGINAL: dd
I know it is 12.8 no load. I said I tested it with the bike not running. I haven't had a chance to test it running again yet. You should try completely reading a post before you respond to it. At the beginning it wasn't charging then if you read it says I rewired the r/r. And have tested it a few timescold (not running) Maybe that confused you but then my next post said my book says it should be 12.8 not runningand that is what I had.and it has been consistant. And I said I have't got to perform the other tests yet. Besides whats wrong with an aftermarket r/r? Oh and I'm not a moron I know that the stator only makes voltage when the engine is running.
If I asked for some help on here for anything, I wouldn't rag on the people I'm asking to help me!!
I read your posts and you didn't mention once whatyour running voltage is. Just your engine off volts. And no I don't think your a moron, yet! If you don't want help just say so.
Well I finally got time to do all the tests today(been working a lot lately). Passed every one of them. So the problem was in the r/r connector. I have heard the Honda makes a twopiece connector for it but have not yet found one. So if any one else has this problem I suggest either getting that or just tearing apart the connector and using single wires. I'm glad to be back on the road.About to go for a ride right now.
ORIGINAL: dd
so what was it that fixed this problem...it sounds like i am having the same problem with my 95. all my conectors to the r/r are single wire connections.the r/r has no burnt wires looks to be ok but just isnt working...im going to try to run a meter on it tomorrow.
ORIGINAL: tislow361
Well I was going to put up a link to the post I followed but I can't seem to find it now. It was somewhere in the 600 forums. But basically you can use an r/r of any other bike with a 5 wire system, they had a how to for one off an r1 and a gsxr1000. The 1000 is easier as it has wires and a connectorcoming out of it as opposed to plugging into the actual unit. If your wires are already out of the original harness and have single connectors on each wire you can just plug it right up. You just have to drill new holes to mount it. Just make sure you check the clearance of the fairing before doing any drilling. Since it is bigger you can only mount it a couple of ways. If your wires are still in the connector just cut both connectors off (the one on your bike and the new r/r) and solder then put heat shrink tubing on them. You can use somewhere around 01-04 gsxr1000 r/r others are compatible so you don't have to get that exact one. Mine was from a 750. I can't remember what all ones are compatible but if you take a little time it is easy to find. Just make sure it only has one connector and 5 wires. Some of them have 2 connectors with ? wires.
This is the one you need.
http://cgi.ebay.com/ebaymotors/Suzuk...spagenameZWDVW
