is it possible...
Side note ~~> I run a 929rr radiator in my 900rr, one tube had to be blocked off but it works.
One of the local stunters told me he made a bracket to mount the two hole tank to an older model 900rr. But if you are handy with a tap and a straight shot with a drill all you need is a new tank for a template to drill the holes in an exact spot. All the mounting spot for the tank is just two threaded spots in the frame. The treads got screwed up on mine and all we did was redrill the holes and tapped new threads. Any questions just pm me and I can explain more if needed.
