-   CBR 900RR (https://cbrforum.com/forum/cbr-900rr-19/)
-   -   petrol question (https://cbrforum.com/forum/cbr-900rr-19/petrol-question-133395/)
cbrjohn Jan 6, 2012 11:48 AM
petrol question
hi guys i have the cbr900rrv model 1997 and was wanting to know if the petrol tank on/off/reserve switch is vacuim fed. in other words do i need to turn to the off part when parked up
estate4life Jan 6, 2012 12:03 PM
CBRJOHN,
The 97' should come with a fuel pump...
honda fuel pump partsmanual fiche cbr900rr cbr 1997 usa
but it's hard to say because previous owner may have mod it to gravity feed... check if it's gravity feed set up...if yes, then yes, swtich your petcock to off position or else it may smell like a gas leak when you fire her up....
but if you plan to park for excessive amount of time like months... then it's always best to shut off.
Thing is I always forget to turn back on, then bike starts to stutter & feels like the clutch is slipping LOL...then to feel dumb.
cbrjohn Jan 6, 2012 12:21 PM
petrol tap
thanks for the info mate i did notice when tank was last of that there was a small thin tube fitted to the petrol tap along with the thicker pipe if this tells you anything
estate4life Jan 6, 2012 12:29 PM
Hmmm? can't recall for sure, if you can take some pic & post, the 900rr section will have the answer for you bro..
74demon Jan 6, 2012 12:30 PM
i always turn off the fuel when parked on my carb bikes, just as an extra safety measure. i just make it a habit to turn it on in the start up procedure.
cbrjohn Jan 6, 2012 12:52 PM
thanks guys
estate4life Jan 6, 2012 12:53 PM
I found this if it helps?
OEM Parts Honda CBR954RR (CBR900RR) 1997 FUEL TANK 96-97 - Cheap Cycle Parts
cbrjohn Jan 6, 2012 01:41 PM
yes thats my setup up as its states in the photo thin pipe nu 25 is vacuim thanks very much
