Need help with turn signal issue.
I just bought new Led turn signals my halogen turn signals worked with the wires and when I changed them to Led all work and run except my left turn signal. It blinks for a turn signal but wont stay running. My right one will however. So in my attempt to trouble shoot thinking maybe it's the wires on the signal I plugged the left turn signal into the right turn signal factory wires and it stayed on plus blinked for a signal.
So I can't think of anything other then my wiring is bad but I just got done soldering the harness back together fixing the person I bought it from hack job of twisting wires and taping them. I've been stareing at my wire harness schematic in my manual and I cannot think of anything. It's a 1994 Cbr 900rr (893) model If anyone has suggestions as to what to try or know what the issue is your advice is much abliged. Thanks, SD |
So you know it isn't the turn turn signal because it works on the other side. This means is has to be in the wiring harness somewhere.
I am going to guess that you have a disconnect in the turn signal/dimmer/horn switch. |
I ran a new wire today and ended up with the same issue.
I plugged the turn signal into the liscense plate port and it will stay on but no blink. so im not sure what the issue is. Any ideas? Thanks, Steven |
Ok, now I don't know what you mean. Can you take a pic of the turn signal? I do know that most LEDs are polarized which means they will only work if you have the current flowing through them in the right direction. Incadescent bulbs (stock) will work with current flowing in either direction.
