Need Help- stock susp. setup info needed for 1994 900RR
OK, so I am a few days late! Here are the stock settings taken from the owners manual.
Front:
Spring Preload: 3rd line from the top.
Rebound Damping: To adjust the adjuster to the standard position, proceed as follows:
1. Turn the damping adjuster clockwise until it will no longer turn.
2. Turn the adjuster counterclockwise approximately 7 clicks so that its punch mark aligns with the reference punch mark. Then the adjuster is set in the standard position.
Rear:
Compression Damping: To adjust the adjuster to the standard position, proceed as follows:
2. Turn the adjuster counterclockwise approximately 1.5 clicks so that its punch mark aligns with the reference punch mark. Then the adjuster is set in the standard position.
2. Turn the adjuster counterclockwise approximately 1 clicks so that its punch mark aligns with the reference punch mark. Then the adjuster is set in the standard position.
Spring Preload: Position 2 is standard setting.
Hope this helps you!
Front:
Rear:
