Need help with build 94 cbr 900
I bought a 94 cbr 900 for $1500 did not run also bought a second one a few days later it was made into a stunt bike (did Run) I believe it is a 97 or 98..... Now to my problem the 94 I got it running but the oil had water in it and was white in color wasn't sure what it was maybe due to being left out side well I figured I would just change motors and rebuild the other later well the motor from the 97 or 98 was laid down and had j-b weld around the stator cover so then I had a friend look at it and said to just switch out the lower engine case well after he had took the motors apart we had found out the inside of The case was cracked inside also well a few weeks later we had a falling out due to I found out he was stealing from me and now I'm sitting here with two motors and have no clue where to start and I do not have the funds to take them to a local shop any ideals or info to help me on the right track would be very helpful I found this forum by searching Google for a few answers but got no where with that
Hey man, just check my thread out. I think that the first thing you should do is downloading and printing the service manual. You have to print it. You can view it on your phone or laptop/PC but it will get dirty and will be slower than just grabbing a book
Take care and have fun! F*ck that idiot. If you have any knowledge about mechanics you should be fine. Don't be afraid to ask. We are here to help you. Do you have a camera?
Sure
I'm also putting my bike together. You can check it out. I'm doing it for the first time;D It will take a while. I have a full time job and it's still cold where I live.
https://cbrforum.com/forum/cbr-900rr...ebuild-145348/
Will it start? LOL
Will it start? LOL
parts are different between model years. 93-95 are the same 96-97 are the same, 98-99 are the same. i know the transmissions are different and the cases are a little different and some others as well. check before interchanging parts between different year motors
baboex
Sep 29, 2012 09:00 PM
