Indicater/Turn signal Relay??
Guys, this maybe a stupid question butI dont have a manual and I need to find out ASAP. I have a 1993 CBR900RR. Where on the bike in my indicater relay?? How many pins is the connector supposed to be??
I am assuming this is whats gone as all of a sudden the flashers stopped working. The fuses seem fine and all it does is make a clicking sound for a second when i hit the turn switch. Please if somebody knows could you help me.....Thankyou
RE: Indicater/Turn signal Relay??
ok, flasher relay is situated behind the clocks. it has 3 wires going to it. GREEN=EARTH, GREY and WHITEwith GREEN tracer. check your connections inside the front panels as well as they sometimes come undone, and under the rear seat unit. if 1 bulb goes it should still blink but very quickly. hope this helps you
I am also having a turn signal problem, any advice would be appreciated. The turn signals and brake light (which is on the same fuse) on my 93 900RR aren't working. I checked the fuse and it is not blown, and also checked all the bulbs. When I operate the turn signal switch I get one "click," and the front-right turn signal comes on and stays on. Is the issue the relay, or the switch, and what is the PITA factor of replacing the relay? Thanks!
muckdawg24
09-17-2007 12:13 PM
