i really need help!
i really need help!
i guess i got hosed when i bought this 900.
i am a newbie to honda's.
the bike looks like it was wrecked before and reassembled.
i'm missing a bunch of parts.
i found the raidator was just flopping in the breeze, so was the fuel pump.
i'm missing the fuel valve extension. ( the part that sticks out so you can flip from run to reserve )
lots of bad wiring. fan is now on a toggle switch. hotwired to the battery.
i think the front end was changed.
raidator is missing a mounting tab an the rest of the bolts are gone. one mount bolt is broken. raidator is resting on the header.( i will fix that first )
just a ton of small stuff.
i changed the throttle cables tonight and the throttle still sticks if the push cable is hooked up. snaps right back with the pull only.
i think there might be a difference with the cable mounts on the carbs.
i guess what bothers me most is the motor is stamped 919.
did honda ever make a 919 in the cbr model?
the guy said it was a 93 with a 96 body kit.
does anyone have the fuel valve extension for me?
why don't the cables fit right?
i'm so lost it's not funny. i really need everyones help here.
i already had to replace the fuel pump relay so it would run.
someone please help me!
i know that cbr year 93-95 use fuel pump...and year 96-99 use vacuum system.
But engine capacity for year 93-95 is 898cc and 96-99 is 919cc (this stamped in the engine like you said). So i guess, your bike is '93 with swapped engine from year 96-99.
If you can't find the fuel lever, just put the valve on RES position, and be sure that you check the gasoline in the tank periodically...or look from the tripmeter... i usually run about 125-140miles from full tank, and refill again...Never ran out of gas
