Got my 95 900RR in pieces, please help me get started with winter project!!!
RE: Got my 95 900RR in pieces, please help me get started with winter project!!!
Yes, it does run. Sounds freakin awesome with the Two Bros. Exhaust on it. As far as the rear sets, I thought they were stock until you got me lookin at them. Now, I am really not sure what they are. Here are a few more pics of "PROJECT FIREBLADE." [8D]
[IMG]local://upfiles/12583/818752470E024B96BFCF957FD4F889F1.jpg[/IMG]
OK, so the rearsets are not stock, they are actually PRO TEK rear sets. They rub on the swing arm so, I think that I will eventually swap the out for something else. Also, yes I did use a paint stripper to get down to the metal. I did that so that I could have the satisfaction of knowing what was really under the paint that I will put on down the road.
While looking at the parts that I have for the bike, I noticed that the plastics that I have for the tail say that they will fit a 98. I think someone was telling me that this will not work for my bike. I have a 95. Does anyone know for sure if the tail plastic will fit my 95?
[IMG]local://upfiles/12583/163F18E020CA49C8A872F4F8A62F9152.jpg[/IMG]
Here is a list of what I really need for this bike immediately:
1. Both upper and lower INNER fairings.
2. Set of passenger pegs.
3. Upper Cowl.
4. Rear Fenders. (the ones that I have are for 98, pictured above)
5. Right mid-fairing.
6. Upper stay for mirrors.
If you have any of this that you are interested in trading for the rear sets let me know. [:-]
3. Upper Cowl.
I can tell by looking at your frame that it's a 96-99, so don't throw those rear fairings out with the bathwater just yet... your motor may be a 95 though, does your clutch cover have an oil window? or do you have to use a dipstick to check the oil lever, and does the front of your tank mount to your frame with 2 bolts or 1?
notice how the area behind the triangle cut out in this 95 frame goes straight up and down with the back part of the rest of the frame?
you're doesn't appear to be like that, it looks like it has more of an angle to it, like the 96-99's, and that area behind the triangle cut out tapers as it goes up on 96-99's, it stays the same width on 93-95's
