Gas tank and upper cowl stay... Pics included
Old 03-03-2012 | 04:48 PM
blubo2256's Avatar
Default Gas tank and upper cowl stay... Pics included
Hows does this mount? i've tried every way possible and it seems impossible to do with two hands.. i've looked in the manual and cannot find a thing
Old 03-03-2012 | 04:49 PM
blubo2256's Avatar
Also.. does the throttle lines thru the upper cowl stay or??
Old 03-04-2012 | 10:21 AM
zaqwert6's Avatar
Nov 2011 ROTM
Not sure exactly what your problem is but i can tell you that bolt in your hand is not the mounting bolt. Its a tie down bolt from the tail section.
Old 03-04-2012 | 10:23 AM
zaqwert6's Avatar
Nov 2011 ROTM
The throttle cablest should run outside of the mounting bosses, they have to be able to move freely as you turn the bars.
Old 03-04-2012 | 02:36 PM
blubo2256's Avatar
Does the rubber piece go underneath the cowl stay or between the stay and tank? Which bolts go there?
Old 03-04-2012 | 02:42 PM
blubo2256's Avatar
can you take a pic of yours for me? Also, this bike seems to be some non-stock bolts besides these two. I feel like 50$+ for a bolt set is a little absurd. Any recommendations?
Old 03-05-2012 | 11:40 AM
zaqwert6's Avatar
Nov 2011 ROTM
Well, there should be a rubber grommet on the tank tab and into the hole in that grommet should go a steel sleeve. Then the stay should have rubber grommets in its mounting hole and another steel sleeve into that hole. That steel sleeve shoould be a "T" wheras the mounting bolt runs through both sets of grommets and seats on the top of the "T" in the fairing mount sleeve.
Heres what I can find on the tank mount, the fairing bushings goes just like that but reversed with #16 on the top under the bolt.
Honestly (check ebay) if your missing alot of the right hardware it might be worth it to get the whole kit and save all the figuring out and running back and forth to the hardware store.... which would be your only real other option.
Old 03-05-2012 | 01:10 PM
blubo2256's Avatar
Thanks again zaq, i'll upload pics of my paint job soon.. It's smooth but the paint dulled out after i wet sanded the clear coat and used rubbing compound... Maybe i should apply polish compound also?
Old 03-05-2012 | 01:27 PM
zaqwert6's Avatar
Nov 2011 ROTM
You def want to use a fine polishing compound or a glaze. Depending on the clear tho you also need to let it cure out for a while before final polishing.
Old 03-06-2012 | 08:37 AM
blubo2256's Avatar
ok.. Does the upper cowl stay go under or above the gas tank tabs?
Quick Reply: Gas tank and upper cowl stay... Pics included
