CBR900RRT rebound damper rod set up?
Hi all, i had to strip the rebound damper adjuster assembly apart as it was seized up and i couldnt turn the small slotted screw in the top of the fork.
I have freed it all up but now i need to assemble it correctly. It says in the manual not to dissassemble it so therefore it doesnt show how to assemble it correctly.
Does anyone know the correct way to assemble it so i get full adjustment? i need to do both fork legs so i will need to get therm both the same.
TIA
TIA
Any chance you would care to provide a general write up of how you solved it?
Having the same issue with one adjuster not wanting to play ball
I realise this post is old , but asking anyways on the off chance it gets answered
