CBR900RRT rebound damper rod set up?
Old Nov 23, 2020 | 09:41 AM
Agemax's Avatar
Default CBR900RRT rebound damper rod set up?
Hi all, i had to strip the rebound damper adjuster assembly apart as it was seized up and i couldnt turn the small slotted screw in the top of the fork.
I have freed it all up but now i need to assemble it correctly. It says in the manual not to dissassemble it so therefore it doesnt show how to assemble it correctly.
Does anyone know the correct way to assemble it so i get full adjustment? i need to do both fork legs so i will need to get therm both the same.
TIA
Old Nov 24, 2020 | 05:53 AM
Agemax's Avatar
All sorted now, i have worked out how to do it.
Old Feb 6, 2022 | 05:12 PM
Dav's Avatar
Dav
Any chance you would care to provide a general write up of how you solved it?
Having the same issue with one adjuster not wanting to play ball
I realise this post is old , but asking anyways on the off chance it gets answered
Old Feb 6, 2022 | 06:53 PM
I guess the question is @Agemax still around and do they recall what they did.
Old Feb 7, 2022 | 05:48 AM
Agemax's Avatar
Hi, to be honest i really cant remember how i did it. it was a long time ago. I am pretty sure i found the answer on the interweb somewhere.
Old Feb 7, 2022 | 06:32 AM
Dav's Avatar
Dav
No problem. Thank you for the reply though! I managed to get it sorted so I am going to leave a SS of the fix I found that helped on my post on CBR600 F4 subgroup .
Old Feb 9, 2022 | 04:34 PM
@Agemax Thanks for coming back and responding.
Naga_Thai
Oct 14, 2022 01:52 PM
Pmcarpentry
Sep 12, 2016 11:37 AM
CaNsA
Mar 6, 2011 10:51 AM
rekride
Feb 20, 2007 05:46 PM
n i g h t w o l f
Oct 19, 2006 10:51 PM
