Bunny hopped over some speed bumps, now firing on 3 cylinders....
Old 09-25-2007 | 10:08 PM
DustThis's Avatar
Default Bunny hopped over some speed bumps, now firing on 3 cylinders....
Just like the title says, returned from a 200 mile ride hopped a few speed bumps now I have one cold header. I have compression, fuelto the carb bowl, clean jets, and spark at the plug but when it's all together I only have three cylinders making heat..... anyideas,CDI box, regulator?
Thanks!
Old 09-25-2007 | 11:05 PM
SpiritRR's Avatar
Default RE: Bunny hopped over some speed bumps, now firing on 3 cylinders....
Have you checked the connections to the spark unit? Is there any water or dirt inside the spark plug wire cap? Is it seated tightly?
Old 09-27-2007 | 12:08 AM
richhowerton's Avatar
if you have fuel air and spark you should have fire, if you are checking the plug with that plug wire ? if you are pulling the plug oput to check it and have spark then when you put it back in nothing, you may have a broken plug wire, when it is pulled stright out it may make contact and when you put it back in the bike you may bend it at the right spot and loose connection? Just a thought.
I would not think it is a coil because youwould not have spark anytime.
lee-jon
04-19-2013 06:50 AM
Assortedqtip
06-30-2012 08:44 PM
buccilator51
F2 Tech
05-07-2012 02:15 PM
wakeyraces
01-09-2012 08:34 AM
DopeBoy239
F2 Tech
07-04-2010 11:27 PM
