95 900rr engine swap
Old 06-19-2007 | 02:36 AM
jrode's Avatar
Default 95 900rr engine swap
hey all i recently bought a 95 900rr that the previous owner blew the motor in. i got a good deal on another motor out of a 97. put it in and everthing seemed fine but after riding it for a short time it started to foul out the plugs. seems like it is getting to much gas. so here is my question does anyone know if the jetting was different on the 900s from 95 to 97. i have taken the carbs completly apart and made sure nothing was gunked up and everything was working good on them but cant seem to keep from foulin the plugs. any help or suggestions that anyone could give me would be great.
thanks
Old 02-05-2010 | 03:45 AM
mlbricker21's Avatar
im fairly new to all this but from what i have figured out about jetting is that it all depends on what mods you have done to your bike such as intake and exhaust and so on if the motor you got came off a bike that needed more fuel than yours due to modifications than that would cause you to be running rich if you think thats the problem
Old 02-05-2010 | 08:08 AM
OLDSCHOOL's Avatar
is it fouling all 4 plugs or one or two also if it was jetting would of had problems immediantly not after a few min check your choke cable adjustment and your float levels was the fuel old contaminated this will also foul plugs
Old 02-05-2010 | 09:05 AM
bambam's Avatar
poss that the carbs used off of the blown motor had problems leading to the blown motor., if you are competent enough to swap the engine, you will not have a problem doing a rebuild on the carbs...if your in it this far, spend the $120 for the kits, retune and ride...
Old 02-06-2010 | 03:05 AM
slight side note i didnt realize when i posted a response to this that it was 3 years old already sooo he may not need help anymore
Old 02-08-2010 | 02:55 PM
bambam's Avatar
thats freakin funny...i didnt see that ...bikes prolly gone by now..lol
Hispeed
08-25-2011 09:12 PM
94cbr900rr
11-01-2010 12:13 PM
mrbf2
12-28-2008 05:07 PM
g900rr
09-25-2007 11:36 AM
