94- LED rear and reg front- not working---Help!!
I have a 94 900RR and one of the rear blinkers went out. I purchased some LED rear blinkers to replace them. They worked for about a week and now aren't doing anything but staying lit when the bike is on. when I press the turn signal I can hear the relay click once but I get a small surge to the rear lights and the front turns don't work at all now. Any ideas. I tried getting a LED relay but am having issues finding one for the 3 wire harness that the stock relay is at. I have tried a 2 wire but cant seem to find a way to make that work and the rear lights still remain on even when the relay is removed.
. I have search all sorts of threads but haven't found anything regarding the 900RR in 1994 with the 3 wire signal relay. . Any help would be appreciated before the police decide to help me out..;-p |
were the lights blinking fast when they were working and did they come with resistors? have you checked the front signals wiring tomake sure they're still hooked up and getting 12v?
you can get an oem turn signal relay from ronayers for $40 http://www.ronayers.com/browseparts....e.ronayers.com |
Blinkers not working
The blinkers did not come with resistors. They did blink faster but not unbearable. I checked the front blinkers and found them to be getting the 12v. I was about to change the front ones to LED also so that the whole system is LED to eliminate different draws.
