93 900rr wiring
Old 02-22-2009, 08:28 PM
keith200b's Avatar
Default 93 900rr wiring
hey everyone, I have a 93 900rr and the wiring has been pulled out of the cdi harness. I wanted to know if anyone knows their locations in the plug or if you could take some close up pics of the cdi wiring for me. i really want to get this bike running. thanks
Old 02-22-2009, 09:26 PM
camaropower's Avatar
I'll post up some pics of my 95 here in a second (i gotta go take a picture first lol)
Old 02-22-2009, 09:58 PM
Edited so I can add diff. pictures
Old 02-22-2009, 10:01 PM
Hope that helps, if you need more just post it, and if you don't need these pics, I'll edit and erase to conserve space
Old 02-22-2009, 10:32 PM
keith200b's Avatar
Default wiring
hey thanks for the pics but it is a lil bit hard to see is there any way that you could take a pic straight on to where the wires go into the plug so i can better see what color wire goes into what hole. i want to get this right the first time. thanks again.
Old 02-22-2009, 10:43 PM
Sure can, but I'll have to do it tommorow, its almost midnight and I've got to get up at 430, not to mention its like 20 degrees outside lol. I'll post up some more pictures tommorrow
Old 02-22-2009, 10:59 PM
I don't know how to exactly show which side is up, but there are 8 places for wires in each of the two rows.
Top Row
blue/yellow yellow/red lightgreen yellow/green (blank) pink white (blank)
In between the rows there is a stamp in the connector that says mxj 52251, When it is facing to where you can read it the wiring looks just like it is written out with the wiring labeled top here being above the stuff stamped into the plastic. And also if it says blue/yellow it means mostly blue with thin yellow stripe
Bottom Row
yellow/blue red/yellow green/white black/white (blank) blue green yellow
Again I'll post pics tommorow if this doesn't help
Old 02-23-2009, 12:40 PM
keith200b's Avatar
Default wiring
thanks again that information will help a lot. if you could still send a few pics so i can just be certain that it is all correct before i power it up. also i dont know if you can get to it but i also need to know about the coil wiring. my coils have a light blue terminal and i would like to know what color wires go to this side. I appreciate your time and help with this.
Old 02-23-2009, 04:57 PM
Here's a much better one, you can use the diagram I typed above to kinda get a bearing of where the wires are at in relation to the writing stamped onto the connector
Old 02-23-2009, 04:58 PM
by the way the wire with the blue tape looking stuff is the white wire
Quick Reply: 93 900rr wiring
