929 rear wheel on a 900 update
Well guys it is official, the 929 wheel does fit a 900 as long as you buy the cush drive as well. The shafts are different diameter but thats an easy fix. You can either use the shaft off the 929 by using a die grinder on the swing arm or change the bearings. Now I have a swing arm that I'm not going to use of a 929. Now I need to make sure I can fit a 190/50-17 on my 900. Johnny
RE: 929 rear wheel on a 900 update
the correct way to do it would be to replace the wheel bearings. Grinding on the swing arm like that would allow the axle to have play up and down, no matter how tight the axle is. one thing ive learned about working on bikes is not to take the cheap way out. After all a set of bearing will only cost about 35 bucks.
