900 vacuum hoses
1999 900rr anyone know where the vacuum hoses go from the gas tank - motor- petcock how many there should be thanks
RE: 900 vacuum hoses
Hope this helps (nevermind the file name ...)
Did you figure the hose thing out?
I need to know the same thing. Help me if you can. If you got a pic that be great steve |
Hey IronFox, thanks for the diagram. It helped me out some. I have a question though that pertains to the vacuum line, that goes into the bottom of the tank (next to the hose for the over flow). Does that tee into the vacuum line that goes to the petcock?
I'm putting together a 97 900RR that soemone else took apart. I have the manual on cd-rom, but the pictures are not very clear. Thanks. |
There is only one vacume line and it goes to the petcock. Then there is the fuel line to the carbs.....much larger than vacume line, then there are two vent lines, one smaller like a vacume line and the other larger, like the fuel line. It should be pretty obvious which is which. The vacume line on the petcock is the small one.....well on the petcock, the one right next to it is the fuel line. Hold on, I'll go take a pic.
Here
[IMG]local://upfiles/7776/6735162C61AB4A57AEEF9238813E80BB.jpg[/IMG] |
Thank you gixxereater!
The smaller line that connects to the bottom of the tank, does that dump out the bottom of the bike, like the large line? If not, where does it connect on the other end? |
It dumps out the bottom. Mine routes through the frame on the left side by the "on/off" valve of the petcock and down out the bottom.
You can see in the pic as it runs into the frame, then back out again right below that. |
Thanks again, gixxereater, that's awesome.
I didn't even notice the line, through the frame, in the picture. |
I got the hayes manual. So if you have any questions I do my best to help. But I a new guy
I have a 99 CBR900 |
