1998 cbr900rr jet question
Hey all, I have above mentioned bike with super short exhaust, oem airfilter and plugs, at higher rpm I miss power when first touching gas, can I adjust the jets and needles I have in there? Carbs are super clean and adjusted. I just try to save money and not buy a kit for +$100' any help is appreciated
Hard to tell by that (not being here myself) , could be rich too.
Hold the rpms right at that point where it is acting up like that and then hit the kill switch. Pull a spark plug and read it. That's will give you the firing condition at that exact point in the range. Then you should have an answer.
At that range, it would most liklely be a needle adjustment.
