WTF is up with this?
After removing the front cowl. And putting it back together. I have no headlights or turn signals AND The FI wont prime.Please help. Lance
Check your gauge connections. All of that runs through the gauges.
gauges work fine. What am i checking for? Lance
checking that the wires coming out of the gauges are properly connected to the headlights and turn signals.... also check the fuses and relays.
yea, definitely check your connections again and your fuses. In case your a real rookie... the connector between the two poles will be detached.
All connectins are good. I have ordered another multi meter/ gauges. I have power/ground going to the gauges. but none coming out going to any relays. Thanks for the help. Lance
