Would u Trust HK Brakes?
Well the question is would u trust in brakes from Hong Kong made by no-name company that sells them on ebay
hers the link:
http://cgi.ebay.com/Front-Brake-Disc...742.m153.l1262
someone said to me that he bought them and they look good and all that, well i know the guy but he doesn't ride the same way i do (hard and break hard )so will they preform as the stock break rotors or better or worse
i went thru all the reviews on their ebay account and no complaints about the break rotors.
what do u guys think about that
hers the link:
I would go with a trusted company for something like brake rotors
I don't think they are flat out not going to work, but they could warp after they go through hard heat cycles. maybe worse case scenario they could crack on you.
How much are you willing to spend? you could get some EBC rotors, not as good as galfer waves but probably a step up from stock, I am assuming your stock ones are damaged, if not i would stick with stock unless you have the cash to dump into nice rotors, in my opinion its not worth the up grade unless you are just worried about looks, or are really pushing at the track. steel lines, better/fresh brake fluid and new pads is a wiser up grade to start with.
http://hardracing.com/Brakes/EBC.htm
I run EBC double H pads and they are good, never tried the rotors but i have heard good things about them.
