whos on line and can help me
RE: whos on line and can help me
i found the fuse,l luclyi there was a spare. the front flashers dont come on and the split yellow on the rear integrated tailinght just stays on solid. Iheard you have to put a relay resistor or something to make it work. Ineed etails and or pics. any help would be appreciated. thanks, Ty
well the fuse for your tail lights is the same one for your front ones. Make sure all the connections are good and if it is some after marked blinkers sometimes they only come with 2 wires instead of 3 like oem, so alls you need to hook up is the negative and positive. Just leave the 3rd wire alone. I'm not quit sure how the intergrated tail lights really work. But I never heard anything about putting a relay resistor in it. Did you buy the intergrated tail light or was it installed when you got it?
