Weatherproofing
Old 02-13-2018, 12:27 PM
Default Weatherproofing
My 05 CBR600rr has a gap between the seat and the rear fairing, I'm wondering if anyone has ideas for weatherproofing since my battery and important wires sit below the seat. I'd like to have more protection against water as we get into the rainy months in Florida. Is this how this generation was designed and all of the connections are able to take a little water? Thanks for the help! Here are some pics to get a better idea of the gap size.
Old 02-13-2018, 03:06 PM
Hawkwind2016's Avatar
I doubt that gap is normal, on my 900 there is no gap at all.
Are you sure that is the correct seat for your model of bike?
Old 02-13-2018, 03:20 PM
74demon's Avatar
Agreed.
Aftermarket fairings??
Wrong or modified seat??
Old 02-13-2018, 05:24 PM
This is what I was given with the bike, my guess is an aftermarket seat. I believe the fairings are stock, it has the tribal graphics which was an option at the time.
Old 02-13-2018, 05:47 PM
74demon's Avatar
They make stock looking faring kits. The aftermarket Chinese ones rarely line up perfectly and are made from completely different types of plastic. It's pretty obvious if you've seen both.
But I would be comparing your seat with other stock ones and see if they match.
Old 02-13-2018, 07:02 PM
Could someone identify the year of this seat then?
Old 02-13-2018, 09:52 PM
74demon's Avatar
It's probably the correct seat pan, but it looks like a crappy recover job with some foam reshaping.
Old 02-14-2018, 05:52 AM
^+1
The vinyl covering looks decidedly un-oem.
As a stop-gap, to just solve your immediate problem, I'd be looking at some rubber sealing strip, like you get around the trunk of your car. It might just slide onto the plastic fairing and provide some protection while you can find a permanent solution.
Old 02-14-2018, 06:13 AM
Interestingly the numbers on the bottom of you seat do not match the numbers on this one here :-
https://www.ebay.co.uk/itm/05-06-Hon...QAAOSwhiZafzGB
Don't know if it's a part number though, 'cos neither number matches up with the parts fiche :-
https://www.mrcycles.com/oemparts/a/...c54be928d/seat
Old 02-14-2018, 09:06 AM
74demon's Avatar
Thats not a part number, it's a manufacturer number. But the MEE code does put that it was made for that line of bikes.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
