Swing Arm Spools/sliders, 08 600RR
Has anyone with an 07 or 08 600RR installed the Sliders or Spools for the swing arm? I bought a Crash Kit that had them. I installed the Left side first, it went on fine. Then When I installed the right side, it didnot fit flush.The mount was set inside a little and the spool would not fit flush with the arm. I had to add 3 washers so the screw would not bend when I tightened it up. Anyone else had this problem?
RE: Swing Arm Spools/sliders, 08 600RR
Haven't installed swingarm sliders yet, but I know the 07/08 swingarm is different than the '06.
Apparently the spool kits for '07+ add a small spacer to use on that side. That's the only difference.
Your washers will work, but I'm going with the more elegant solution
The more elegant solution isthe small spacer, I was just being a smartass.
BTW, the "spacer" isnothing more thanathick washer, so you have to only use one
If the kit was specifically for the '07/08 RR it should have come with either a spacer, or one of the sliders would have a narrower base to reach the mounting hole before hitting the side of the swingarm. that should be the only difference between a <'06 kit, and the newer ones.
You should have no problems running with your setup.
