RE: side pipe
ORIGINAL: TheX ORIGINAL: ground zero ORIGINAL: skitzofrenzy custom prob, but there are some really expensive side pipe conversions... search you might find it, i know i contributed to osme thread about it. btw you cant put a 1000 pipe on a 600, you will burn out your valves |
RE: side pipe
I have a feeling that this thread has sidetracked, but you would most likely want to remap with a different pipe, whether it is from a 1 liter, or from it just being a freer flowing pipe. I doubt any of them would lean out the mix enough to burn valves, but why not compliment the pipe with a correct tune?
RE: side pipe
GP makes an ehaust but I think its primarily for the Yamis
RE: side pipe
I kinda like the arrow dual system. I wouldn't have it unless I had 5 cylinders though....
RE: side pipe
I was more referring to gains over a single pipe full system, but that is still a definate improvement.
RE: side pipe
well if you have a pipe that is not made for you bike, for the right back pressure or whatever it can burn your valves.... just like taking off your pipe to begin with right? i mean you have to have the right back pressure... someone back me up cuz now im doubting myself
RE: side pipe
ORIGINAL: skitzofrenzy now im doubting myself |
RE: side pipe
crazyness, first thread of mine that people got interested in... thanks for all the info , and if anyone has anymore info let me know
RE: side pipe
Having some backpressure is important, but it would most likey not solely cause you to burn valves.A freer flowing exhaust causes a leaner mix, and a leaner mix makes the exhaust temps higher. Exhaust temps that are too high can burn thevalves and ruin them.
RE: side pipe
well shoot idc much anymore haha. if im wrong then someone put a 1k pipe on a 6.. then tell us if it continues to run right. ill keep my yoshi pipe tho :)
