How do you pull decals?
RE: How do you pull decals?
actually pretty easy....just takes a little time and use a blow drier for the heat and makesa a lot easier
the only one you might consider not doing is on the tank...it is clear coated in...I did it anyway, but can tell up close
even if don't do....definitely pull all decalls off swing arm and stuff like that
later bro
later bro
seriously, really easy....and just leave the tank decals on since want showroom finish....all the rest were simple
just don't use a razorblade or anything steel...if need to use somthing to help with areas that aren't coming off easy...make sure plastic and no problems on clear coat then
post some pics once done
