Removing Decals
Old Dec 8, 2005 | 11:20 PM
capa112's Avatar
Default Removing Decals
Anybody have some good suggestions on the easiest and fastest way to remove decals.
Old Dec 9, 2005 | 12:20 AM
dballer324's Avatar
Default RE: Removing Decals
heat gun or hair dryer if you don't have one...then just get em hot and peel off...
Old Dec 9, 2005 | 01:43 AM
cjbettis's Avatar
also if you need to scrape in some places...make sure you DON'T use metal/razorblade....use a plastic one...not hard at all and makes it look like you have a cutsom paint job....I did it to my bike..check out my photos...hope it helps
cjbettis's Avatar
hey, how come you haven't posted any pics or an avatar for you yet?
Old Dec 9, 2005 | 01:51 AM
NINE2NINE's Avatar
Retired Mod
how did you get the decal off of the tank? isn't it clear coated over?
Old Dec 9, 2005 | 05:58 PM
cjbettis's Avatar
yeah...it WAS...very minimal scratches....you can get all sorts of compounds that fill them in, wax, buff, gone
Old Dec 10, 2005 | 12:40 AM
sireg's Avatar
really...buff and wax? thats wierd i just took the stickers off my 03 rr and i needed to get the tank resprayed. after i wetsanded the top layer of clear off the stickers on the tank i peeled them off and it was like two different colors. i tried to fether the edges back on the top layer of clear to blend it in but it didnt work to well. i work at a car dealership so the manager in the bodyshope told me 100$ to respray the tank
Old Dec 10, 2005 | 12:48 AM
cjbettis's Avatar
you can barely tell on mine...unless total looking for wouldn't notice...the only thing was a small indentation where the decal started all the way around...ask at the car shop...they have stuff for minor scratches....no just waxing and buffing alone wouldn't do it
fyi - I will be having a custom paint done to the entire bike....like this look way better then the stock...but definately not show quality
but then again I just road ride with cruisers....I look so much better then they do no matter what....plus looks custom for free until the $ to make it out of this world
Old Dec 10, 2005 | 10:45 AM
regener8ed's Avatar
the warmer, the better (heat gun, blow dryer, even helps to drive around and let the fairings get warm) -- the decal will be less likely to tear and the adhesive usually comes off cleaner. to remove remaining adhesive i recommend acrysol or some other denatured alcohol.
Old Dec 10, 2005 | 07:04 PM
FordFrenzy97's Avatar
If I may suggest, use a blow dryer not a heat gun. Takes longer but heat gun can melt the plastic.
