removed Cailfornia smog & now it runs like sh*t
I need help. I removed CA smog equipment " the evap can. , pair valves,pair valvesylinoid, and oxigen sensers" & now my bike (04 cbr 600rr) will barely run. It won't idle at all. and it smells like fuel big time & runs hella rough will only run while feathering the throttle. I capped off all the vacum lines... I don't know what else it could be?hopefully someone knows in here. the only other thing I can think of is maybe get a 49 state E.C.U. because it wouldn't be searching smog ****? but correct me if I'm wrong. Its driving me F$#kin CRAZY, I don't wanna take to a dealer if I don't have to... please help a cbr brother in need, thanks
RE: removed Cailfornia smog & now it runs like sh*t
error codes?
Yep, the ECU is probably freaking out because it is searching for equipment that's not opn the bike anymore.
The rough running, and fuel smell is the bike running WAAAAY rich to try to save itself (on cars with the check engine light; that light would be flashing at you in what is commonly called "limp home mode" ) Why did you remove the smog equipment anyways? |
