PLLLLEEEEASSSSE HEEEELLLLLPPPP!!!
06 600RR... I was riding it the other day and locked up the rear brake to spin the bike around, going like 5 m.p.h. Anyway, my clutch work wasn't too good (lol, hahaha) and the bike died... so I go to pull in the clutch, it doesn't turn over, gauges are good though, full power... then put it in neutral, same thing- neutral light is lit green, rpm gauge bounces back and forth but it doesn't crank. So I have my friend help me PUSH START it... NOTHING. It doesn't even sound like its tring to spark or get fuel. So I truck it home... TODAY- I check ALL fuses, including main fuse and 10amp inline fuse, and all the fuse box. ALL FUSES ARE CODE-4. One thing I can CONFIRM: When I turn the key on with the switch in "run" position there is NO click from the starter relay and NO noise from the fuel pump.
PLEASE HELP!!!???[/align] |
RE: PLLLLEEEEASSSSE HEEEELLLLLPPPP!!!
Check the connector to the fuel pump. Mine came loose once with similar symptoms.
That's under the gas tank correct?
Yep! PITA to get to.
I do not know on your bike but the conection on the starter relay on my 954 came loose after kind of the same stuff. it is under the seat.
