PAINTING BY THE NUMBERS
RE: PAINTING BY THE NUMBERS
nothing more annoying then people writing with full caps on...
anyhow, you can do a few ways with painting. The cheapest route is to use rattle cans you can get from any automotive store. You prep up the pieces using sandpaper and body filler (if needed), primer, prep for paint, then paint, and clear (if needed). Another route would be to have equipment to paint such as a large air compressor, HVLP paint gun, lines, primer, paint... Pretty much almost the same steps, but having your own equipment makes the job look more consistent and nicer. Although, I've done rattle can paint jobs to look like it was sprayed by a pro. Just to let you know, its like 80% prep and 20% spray. Lots of work sanding it down. If you don't do a good prep job, your paint will look like crap.
