Oil Change Now???
Oil Change Now???
I'm in North Carolina and its about time to pack our bikes away for the winter. My bike is due for an oil change. Should I not worry about it since the bike isn't going to be running for the next few months and change it next Spring??? Or should I go ahead and change it now and not worry about it in the Spring?? Or does it even matter??
Thanks
Thanks
RE: Oil Change Now???
change the oil/filter before you store it. you don't wan't used oil sitting your bike for months. used oil is contaiminated with acids and other harmfull elements that can corrode internal engine parts. also fill your fuel tank and put stabil in your gas and run it for 5 minutes before you store it
ORIGINAL: ninetyfivehp
Gasoline stays fresh for a very, very long time.
stored gasoline degrades in as little as 60-90 days. stabil is cheap insurance against running your bike on stale fuel which could cause the bike to run poorly or cause detonation. 2 oz. treats 5 gallons. better safe than sorry. your bike and fuel system will thank you
