not sure if this is a problem or not
this doesn't happen all the time...but lately when i start up my bike, i rev the engine up a bit to get it going while idle...but at the lower rpms it doesnt seem like it wants to rev. now, i'm thinking bc its the cold weather and the engine hasn't warmed up yet...but i've never really experienced this before and just wanted to get some input. last week, i started it up...put up the kick stand...reved it up...and it died on me...i started it up again and reved again and worked fine. i didn't ride for maybe about a week before this(and i normally ride everyday...so maybe b/c it was sitting for a while?), but just wasn't sure if this was normal.
RE: not sure if this is a problem or not
hmm... yeah... i'm with tahoe... this is not normal. i've ridden in the teens up here in IL and when i start it up i've never had that problem. you probably don't need to rev it while it's warming up. in fact, when it's COLD out i don't touch the throttle till it hits 100 degrees on my temp guage.
dont think that would make it die right off the bat... I dont rev mine either till it hits at least 100, usually 120-130, then i will take off an run it slow so as not to annoy the neighbors, but then again, maybe im overcautions... but I do believe it takes a bit for the oil pick up an all that to get what it needs, so i let it idle without revs, even when its warm out, if its first start of the day, she idles till the temp picks up... not sure... im only sure I prolly didnt help but only wasted your time, but i tried [&:]
good luck,]
Chris
good luck,]
Chris
ORIGINAL: BlindLOKI
good luck,]
Chris
good luck,]
Chris
