*****NEWBIE, NEED HELP******
RE: *****NEWBIE, NEED HELP******
ok from the manual.... To select Fahrenheit and Centigrade, push the RESET button with the display in the tripmeter B mode......okay now to change the time, press and hold the ADJUST button and RESET button for more than 2 seconds. The clock will be set in the adjust mode with the hour display flashing... To set the hour,push and release the RESET button untill desired hour...then push the ADJUST button for the minute display and that will start flashing press the RESET button till the desired time and to end it prees the ADJUST button or turn it off...
arcotc
01-13-2021 02:45 PM
