My tacho donīt work - CBR 600RR
Hello everyone,
I have a kartcross with cbr600rr engine. year: 2008 ecu and loom: hrc The engine speed in the cluster dont work, stay on zero rpm. I take the signal from tacho (yelow green wire) with a scope. when the dashboard connector is pluged I have about 1v constants. If it is off I have a square wave oscillating between 5v and 15v. Will the ecu be broken or will it be the dashboard? thank you |
Hi check the VSS (vehicle Speed Sensor)
The engine start normally.
I think that if the sensor was damaged the motor would not start. Thank you |
