lubing the chain
lubing the chain
The other day i was around some of my friends that ride and one person said that you should lube your chain everydayand then another guy said that you should lube your chain everyother day...what i want to know is when should you lube your chain and what lube should you use
RE: lubing the chain
If it looks dry lube it. Manual says every 500 miles or as needed. You certainly can't over lube it. The most important thing is warm the chain up with a lap around the block then lube it, this will draw the lube into the o rings. I made the mistake (with my factory chain) of lubing after detailing my bike while the chain was cold. Then the lube would pretty much sling off the first ride after and not really penatrate into the o rings. My .02 Oh yeah, I use chain wax, can't remember the name tho.
no everyday/everyother day is not needed... maybe everyother fill up or once a month depending on how many miles you ride and more if you ride in rain or dirt more often.. chain wax is nice.. a good trick is after a long day of riding.. put it on the rear stand, put it in 1st gear and let it freespool and spray it on the chain as it goes around and then shut it off and let it dry on the chain, then you are all ready for the next ride
quote] a good trick is after a long day of riding.. put it on the rear stand, put it in 1st gear and let it freespool and spray it on the chain as it goes around and then shut it off and let it dry on the chain, then you are all ready for the next ride
[/quote]
this works well for oiling the chain yes...but is a VERY bad idea for cleaning a chain [8D]
[/quote]
