just changed my oil..helpp!
i just got finished changing my oil for the first time on my new to me 04 cbr 600rr. i did it exactly how it says in the manual. after i added my 2.9L of oil and started it up and let it idle for 5mins or so...probably longer i shut it off and let it sit for a few more mins (exactly what the manual says). but according to the sight checking window there is no oil it. is this relativly normal or is something wrong?
also, how much noise is you CCT suppose to make, i can definatly hear mine but i dunno if i should worry about it or not.
thanks
thanks
this is normal after you add your oil and start up the bike for the first time. the oil is going to run through the engine. add some more oil till its at the correct spot in the gauge window. next time you change your oil follow these steps,
1. drain your oil, change your filter etc etc, you seem to have that part down
2. Fill it up with oil to the correct ammount as shown in the window gauge
3. start your bike and let it run for prob 10-20 seconds, just long enough to let the oil flow through the bike. then shut the bike off and top the oil up to where it should be.
4. Then you can run your bike for the 5 min and see where the oil sits. adjust as needed
5. Be proud you did it yourself instead of paying the crooked dealership to do it for you.
You have to remember when you put your oil filter on it is empty. So when you start the bike the oil goes through the system and fills up the filter. The filter will not completely drain when you turn the bike off and when it looked full at the start, it will now look empty. Just top her up.
its all good now, thanks guys.
how about the other question, how many peoples cct makes some noise? i can hear mine a bit. It doesn't sound like its gonna blow up on me but you can hear it slightly. should i be worried about it and get a manual one? or is it "normal" for it to make some noise?
How many miles does your bike have on it?
