injectors
What size are the stock injectors on the 2004 600RR? I've been searching through google and have come up with no results. All I know is they're made by Denso.
Thanks in advance. |
RE: injectors
75 micron IIRC
RE: injectors
Knights is correct, what are you working on?
RE: injectors
i can't remember if that's for the primary injectors or the secondary (overhead) injectors though. i'm pretty sure Primary.
RE: injectors
Thanks, but I've never seen injectors sized in units of microns. What is the size in terms of cc/min or lb/hr? I'm using a standalone for engine control and I was wondering what the injector size was so I can calculate pulsewidths. I have a custom IM, and I'm only using the primary injectors.
RE: injectors
Really? i thought it was quite common place... but you're not looking for size though. You're looking for delivery capacity. that's information, i'm afraid, i cannot provide you.
Originally Posted by LRS122
(Post 417844)
Need the cc/min figures..so, yes, the flow rate is what I need I could care less about how big the holes are. :) -Chris |
noobs must be all thinking alike because I was just looking at the wreaked bike i bought wondering what size injectors it had cc wise stock. Any you senior members know of a good place that would have just technical specs for the 600 rr models. I'd like to research all I can on this bike till I know it inside and out. Like I've done with the RX-7 for the last decade.
Injectors on my cbr 929
Originally Posted by knightslugger
(Post 413637)
75 micron IIRC
Mr.
(Post 413492)
Thanks in advance. Happy riding. Micron size pertains to the size of the holes the fuel squirts out of, although important info, I would assume it’s the flow rate you were looking for |
| All times are GMT -5. The time now is 05:16 AM. |
