Idle speed adjustment 09 600rr
Hi How do you adjust the idle speed on a 09 600 rr? It is reving at nearly 2000 rpm but doesn’t drop when warmed up. Thank you in advance |
Sorry not my bike but if she’s injection which I believe she is, then the idle is set by the ECU.
Throttle stop arrangement might be worth examining? Sorry couldnt help further mate. |
There should be an adjustment cable somewhere, usually on the left side under the farings.
Low coolant will also cause a high idle. |
1 Attachment(s)
Hi, no manual adjustment but have a look at this
