-   CBR 600RR (https://cbrforum.com/forum/cbr-600rr-12/)
-   -   idle issue (https://cbrforum.com/forum/cbr-600rr-12/idle-issue-90344/)
dwschultzy Mar 30, 2009 11:20 AM
idle issue
04 cbr600rr
bike idles fine in neutral....when put into gear it jumps up 2k in rpm's
ideas?
Baooo Mar 31, 2009 03:01 PM
had an issue with mine idling at 5k. sorry i dont know name but ill try to explain what was wrong with mine. Their is a cable that connects under your throttle body. Mine sits out on left side of bike under the plastics, its a black cable and has phillips screw on the end. try adjusting that and it may help i found out mine broke and i had to replace the cable and idle control valve thing it went into. only 75 bucks from dealership so good luck
600RRWatson Apr 4, 2009 10:42 PM
idle air control valve (IAC) it routes air around the throttle blades at idle and at open partial or wot it should stay closed but if your having a issue with the idle its prob sticking or freaking out for one reason or another
