I need some help tio get her back on the road
so this morning i told my girl to start my bike(04 600RR) and by accident she left the ignition swith stuck on, i noticed and fixed it. I went on with my day, well i was leaving and i tried to start the bike but no start. When i turn the start swith to ON i can hear it go on, and i try the swith and nothing, so i just jump started it (did the running and dropping the cluth thing) just to get me home. So right now i'm about to take her apart..... I'm thinking 1) just the ignition swith 2) a fuse 3) starter....thats all i got. SO i was wondering if i can hear ya'lls input regarding my problem. I'm also trying to self-teach mechanic work as i go along. Thank you for ya'lls time
---Alex
---Alex
I would follow my wires if not that ummm pull the clip-on housing off and see if the wires in there are all gravy..... If that dont work i would see about the fuze... when you take your seat off there will be a main fuze i think its 15amps that runs the main housing i would check that one first...
Ghost
Ghost
My 06 did the same thing, turned key everything came on tach went up then back down...lights ect. I hit the button st start it ...nothing. I checked fuses and it turned out my battery had enough juice to run everything just not enough juice to turn the bike over.....hope that helps.
I was able to jump it or clutch start it but as soon as I turned the bike off it would not turn over....
I also charged the battery and it showed that the battery was fully charged and still would run everything but would not turn over
I changed my battery 2mnths ago and everything is fine
check your battery
check your battery
