-   CBR 600RR (https://cbrforum.com/forum/cbr-600rr-12/)
-   -   how did i get an FI light? (https://cbrforum.com/forum/cbr-600rr-12/how-did-i-get-fi-light-139739/)
mmp1214 Jun 29, 2012 12:29 AM
So about a month ago i went home for summer vacation and left my bike at college, yesterday i went to turn on my bike and my battery was dead. Since it has already been 9 months since ive been riding and the battery was never replaced before that i thought why not just go out and buy a new battery. so i went to the dealer and got myself a new battery. I came home and swapped out my battery (which was such a pita btw), and then proceeded to hit the starter. The bike was in neutral, the kick stand was up and i was sure that i had reconnected every single wire that was connected to the battery and definetly made sure that i did disconnect anything i wasnt supposed to. When i hit the starter, the bike cranked and wouldnt turn over. I looked over at the cluster and the FI light was blinking. It would blink once, pause, blink twice, pause, and blink 3 times and do it again and again as long as the bike was on. The other thing was that my bike usually makes a noise when i turn my key to the on position which is what im assuming the bike priming the fuel injectors*. The only electronics my 2008 cbr has are a scorpio alarm system, two brothers fuel controller, and red led lighting. The only mechanical upgrades i really have is a full two brother V.A.L.E. exhaust, driven sprocket and chain. does anyone know what my issue is, cause i just cant seem to figure it out?
Cheers
Mugat
74demon Jun 29, 2012 12:38 AM
When you changed the battery, did you have to reset the alarm system? I'm sure the alarm has a fuel pump interrupt, among other things, to keep it from starting. Whatever is being interrupted, is likely to be the cause of the ecu responding with a fault code.
yumoncbr Jun 29, 2012 12:42 AM
With gsxr, FI light maybe caused by set valve / exhaust valve. with stock or slip on, bike uses the on/off switch. But with aftermarket full exhaust, bike doesn't need it. So normally when you install full system, you remove them or at least disconnect the cable so it will remain open all the time. So if you haven't remove it, that might be causing it. Or bike might have some electrical short somewhere.
sincalirider Jun 29, 2012 01:41 AM
Can you double check the blinking? It doesn't seem right. A long pause is a a "10" and a short blink is a "1". So it seems you have two faults but the last one isn't in the service manual. For a reference to the FI faults check out this thread
Trouble Codes : Honda CBR 600RR Sportbike Forum : 600RR.Net
There's the 1st post and the 6th post that has the codes posted.
mmp1214 Jun 30, 2012 02:02 AM
Okay so I checked again and its def one blink then two and one blink and then three.
So its def 12 and 13 from the link that was posted. So I just have a bad injector connection or faulty injectors?
sincalirider Jun 30, 2012 04:16 PM
Looks likes it. Pull out the air box and have a look at the connectors.
mmp1214 Jul 3, 2012 01:10 PM
how has the world become so evil ?
It turns out nothing was wrong with my bike. The shop stripped the whole thing down and couldn't find anything. When one of the mechanics who wasn't working on my bike came over and looked at he immedietly noticed that there some wires cut right where the fuel injectors were. They ffigured out they were the reason I was getting an FI light. So I'm guessing while I was at home away from my bike I guess someone thought it would be funny to cut all of the wiring. A**holes. I don't get why someone would do that to another belongings. Anyways it cost 350 for 4 hours of work for something that could've been a ten min fix.did get my oil changed for free in the process, except I had to pay for the oil...
74demon Jul 3, 2012 01:26 PM
People that do that, and I say people because dogs are way better than them, should be shot.
yumoncbr Jul 3, 2012 07:16 PM
NO really? That's totally ****ed up.
