HID on 07 RR
Old 01-11-2008, 10:57 AM
Default RE: HID on 07 RR
ORIGINAL: Bear600rr
The kits (H7) seem to be available in 5,000, 6,000, 8,000 and 10,000 color temperature. Am I correct that the clearest pure white highest intensity woould be the 5,000.
that would be the most white but the 6000k is i think the brightest after seeing them all and i would recommend the 6000k for our bikes
  #22
Old 01-11-2008, 11:57 AM
redbbwoy's Avatar
[sm=ttiwwp.gif]
  #23
Old 01-11-2008, 08:53 PM
so you're saying that the H7 super slim 6000k auto conversion kit is the best option? it says something about having to give up the high beam - what's that all about, or does it not apply?
  #24
Old 01-11-2008, 09:13 PM
also, does that mean that the 10000k blue isn't as bright on the road? i'm not sure i follow, but i'm borderline tard.
  #25
Old 01-11-2008, 09:23 PM
Blue Fox's Avatar
Retired Moderator
As long as the HID kits are H7's, it doesn't matter what year websites say they're for.
For the 2007, you will have to drill a small hole in the caps that covers the access to the bulbs to fit the wires through. No big deal though, the bulbs have a rubber grommet on there to seal up the hole.
I haven't dealt with the mini-ballast kits yet, but I have purchased quite a bit of HID kits, all from the HID-Outdoor Equipments eBay store that was mentioned above in earlier posts. GREAT product, great customer service and not one of those kits has let me down yet. (and I've had one of mine for well over a year).
So, as long as you get the H7 auto kit (auto kit has 2 of everything, motorcycle kits only have 1 of everything), you'll be perfect. I do recommend getting the new mini-ballast kits for the 07/08 models. Space is even tighter on those than on the 03/06 models.
As for the color temperature...............the closer you get to the 5000k color temperature, the better. The 4300-5000k HID's are going to be a true-white and produce the brightest light output onto the road. 6000k's have just a little more blue in them (but still white on the road). The higher you move up the scale, the more blue/purplier they become..........but they also loose brightness the further up you go, so sticking around the 5000-6000k mark is the best bet.
If you guys have any HID questions, let me know.
  #26
Old 01-11-2008, 09:52 PM
ok, thanks for clearing that up. i was always under the impression that the higher the number the brighter the light, and that other colors (like the blue) somehow travel farther or reflect differently to give better vision. but like i said above, i'm not that smart.
  #27
Old 01-11-2008, 09:56 PM
ORIGINAL: Papi Chingon
You're alright. The system, in terms of light output vs. color, is backwards. Don't worry about it.
  #28
Old 02-08-2008, 06:23 PM
Hey mine didnt come with this rubber grommet, I dont know what to do since if I drill a hole in my 2007 casing it wont be water tight. Im not sure what to do since Ive had the lights for a week and went to try it today and you need to go out through the back light casing (by drilling). How else could I runthe wires through a hole and make it water tight?? I need some help here and I really want to do this already. Thanks anyone for any help...
  #29
Old 02-09-2008, 01:47 AM
In for pics!
  #30
Old 02-09-2008, 10:14 AM
aaron1085's Avatar
looks bright!
